No following your explanation… For my setup, how should I set it?
If you plan to use “Relative Z Moves Only” it technically doesn’t matter in this case. But if you want to be able to see items in the library sorted by thickness, so the Z offsets are correct, you should use the proper material thickness values.
The function is still erratic. Unfortunately I have to downgrade to V8 to get it working again.
