Laser beim abfahren des Rahmen ist trotz 0,01% noch immer zu stark und brennt sich ein (Laser when driving off the frame is still too strong despite 0.01% and burns in)
Laser beim abfahren des Rahmen ist trotz 0,01% noch immer zu stark und brennt sich ein.
Kann man den Laser noch wo schwächer einstellen?
Für die Rahmen Vorschau.
Das versaut die Gravur oder Schnitt.
Es ist ein 20W (Ausgang) Dioden Laser.
Laser when driving off the frame is still too strong despite 0.01% and burns in.
Is there a weaker setting for the laser?
For the frame preview.
This messes up the engraving or cutting.
It is a 20W (output) diode laser.
It’s possible your settings are incorrect.
What is the value of S Value Max in Device Settings? What are the values of $30, $31, $32 in Machine Settings?
The laser is still too strong when driving down the frame.
He leaves traces.
S=1000
$30=1000
$31=0
$32=TRUE
I feel that this might mean the traverse lines (or travel moves) are engraving.
If you have a small project that has the symptoms you describe, and if you are comfortable sharing, select File, then Save GCode then upload the GCode file and the lbrn2 file here.
Even a project that is only a simple shape like a square or a circle - if it has the symptoms you describe it’s an excellent diagnostic tool.
A screen capture of the Preview window is also helpful.
It’s about previewing how the placement and size of the motifs to be engraved will be placed. Not the engraving itself. The crazy frame with a laser is burned into a sensitive surface. The laser is set to minimum power and is still too strong (0.01%) laser power.
