Laser cannot be found
I was using my laser and then I connected an ssd while the laser was connected and it disconected and in the console it said port failed to open already in use. I tried a bunch of things and nothing is working so I disconnected my laser and now Lightburn cannot find my laser. I use a Mac also. What do I do?
Try this:
  1. First disconnect the SSD
  2. Make sure the correct serial device is selected in Laser window in LightBurn
If the computer you are using is a MAC the port may not be providing enough power. Not that familiar with MAC but you might check to see if the SSD is drawing more power from the port it is connected too so the laser USB port is failing. Not sure how many ports you have on a MAC, but something to check.
