I have tried everything and I’ve read everything but nothing has helped me. I’m trying to center my work. I have the green dot dead center of the work area, I have my artwork centered around that dot. I use the “set layer position by clicking” button. The laser moves to the center but when I engrave it’s off center by millimeters. I don’t know what to do now. I’ve read the forums, I’ve tried everything I’ve read. Please help.
What mode are you using in Start From: in the Laser window?
Can you attach a full screenshot of LightBurn with the design loaded?
Try switching to current position in Start from. You may have a user origin set that’s throwing off your position.
That worked!! Such a simple fix lol, I feel so dumb.
Don’t let it keep you up at night…
I’d be worth what Bill Gates is, if I got 5 cents for each time I felt that way since I started with these machines…
