Hello,
Is there a setting in LightBurn to compensate for the cut width of the laser beam? For example, I’m cutting a dovetail joint in 1/8” plywood for joining two pieces together. The cut is a little loose for my liking and I want a tighter fitting joint. If a compensation feature is not available, Is there another method that may work?
