Laser cuts inverted...good side down. where is the control?
The laser is cutting with the finished side down. Ok for cutting but not engraving. How/where do I control it?
Are you referring to the orientation of the burn vs what’s in workspace? If so, that’s likely caused by wrong Origin value in Edit->Device Settings. Most GRBL machines should be configured bottom-left.
Do you mean flipped/mirrored?
It sounds like your machine setup is not correct.
That fixed it! Thanks!
