I have got everything working, except…
The laser moves into correct position ready to cut a shape (say simple rectangle), but before cutting the shape, it moves in a line with the laser burning on the Y axis to the front (Y0). Then it burns back along the same path before burning the requested shape. I have tried this using a PC running Microsoft 11, so is not a mac / PC issue.
Is this some setting that I need to change - Any help appreciated!
Running latest version of Lightburn on MacBook using High Sierra (10.13.6)
Laser is a Benbox.
Thanks for the help
I have done a bit more testing …I created the letter S with the type tool, and depending on where I place it I either get or don’t get the problem. Mostly the problem occurs, but If I try moving it around the space it will sometimes work. No other settings are changed.
I have attached the Lightburn and the gcode file (I can’t see anything there, but I am no expert) with it in one of the positions where it occured.
