Laser cutting in wrong place
So I’m tying to chase down a gremlin. I’ve got all my settings right as far as I can tell.
However it’s like the machine is hanging up on cutting for certain files. It skews the location that I tell it to engrave. Often causing it to hit the limit sensors.
This most commonly happens when cutting 2 colored parts (2 different laser cut settings)
In the photo posted, this image is cutting in the upper left instead of upper right. And I know I have the orgin set right because if it’s a single file, it cuts perfectly. I’ve tried sending via USB and Ethernet to no avail.
What are the setting for ‘start from’ and ‘job origin’ in the laser window?
