Laser daviation
How can it be that after I started a new job and in the middle I want to improve several elements and for that matter I stop the work, improve what is needed, delete the layers that have already been done, try to return to work and discover that the machine has deviated from its original position by several millimeters?
For repeatable positioning it’s generally best to use ‘Absolute Coords’ as your ‘Start From’ mode. That will also depend on your machine homing properly, and you should re-home after any halted job.
Here are a couple of resources on the different ‘Start From’ modes:
Thank you very much
