Laser does not turn off
Hello, my laser does not turn off between movements leaving laser marks. What should I do
Welcome to the forum! You will find the support level here is fantastic.
For a laser, GRBL parameter $32=1 should be the setting. You can check by entering $32 in the Console window. Entering $32=1 in the Console should fix it. Entering $$ will give you the entire list of parameters. You should copy this list into a text file for safe keeping.
Hello, I saw your advice but the parameters I think are correct. I send photos of the errors and parameters. Thank you
