Laser don't work
Hi there,
I’m a total newbie and I’m still studying and testing the lightburn on my Longer 5 Ray 20W. Until now I’ve two problem:
1- I tried to engrave on a wood plate a sort of chessboard, for know where put the wood during a work. I give 1cm of space all around and… lightburn just engrave the three middle square and stop to work.
2- I tried to engrave an image, the laser worked perfectly until blocked because there was no more rail for go up. But in the working space everything was perfectly fine and in the limit of the working space.
Any advise from the “seniors”?
Was there an error message in the Console window?
An image can fit in the workspace, but Overscan can make it go out of limits. Turn on the Show traversal moves switch in the Preview window. Everything should be inside the green box outline.
Hi,
First: thanks for your time.
Second, I’ll try tomorrow for the square board but, for the outside image, I looked at it and, theoricaly is inside the work space.
Sorry for the italian version of Lightburn :wink:
Lightburn is used all over the world.
Yes it is. This suggests you are not using Absolute Coords in the Laser window. You must have a good grasp of coordinate systems and offsets to use the Current Position and User Origin settings.
By using Absolute Coordinates, your Lightburn grid positions match the laser module positions. No math or corrections are needed. You can imagine the Lightburn design grid hovering above the laser machine, and wherever you have something in the design, that is where the laser will go.
