Laser feature missing
Hey all! I noticed after the update that the laser feature is no longer showing in my program. Can anyone help me?
You mean Laser window?
Try Window, Reset to Default Layout.
yes the laser window.
Did the suggestion work?
Yes!! Thank you so much! I am new to this and still trying to figure it all out!
I did encounter something else. When I type in words the laser is reading it as one solid line.
I think you meant Lightburn, but that is normal. You created a text object If you want to separate the letters, you have to Convert to Path and they will become separate objects.
EDIT: But they will no longer be editable test. If you want that, make each letter of the word separately.
