Ok, I’ve been using Lightburn since March, and I’m getting sick and fcking tired of every time I hit the fire laser button, it will randomly shut off on it’s own. Absolute bullsht
Try a larger power supply. I had the same problem with mine.
As Tim mentioned, this is usually caused by an underpowered power supply browning out and causing the Laser’s controller to reset - contact your manufacturer for a replacement (or find an alternative with the same voltage rating and plug, but a higher current rating.)
