I bought an svg clipart and center traced in inkscape and into LB no problems, but when I frame the img my laser fires in burn mode not frame mode randomly. I have an 20 watt Ortur. If I reapeat the frame 3 or 4 times the random burn firing stops then I can burn but sometimes when the burn is finished the burn laser stays on in the rest position for 5 sec or so. I have always burnt img files and not traced ones and never had a problem
I was thinking maybe something in the code telling the laser to start burning but the thing is each time I frame the random burn is different and will eventually stop
Didn’t know if anybody may have had this problem
This is likely a failure in the laser module or in the controller.
