I have my 108.35mm x 108.35mm tile in position, I have my C01 Layer Line 1 parameters already set, I have my Job Origin position set in the middle and the Start From set at the “Current Position”. I then click on the “Set Laser position button” then I click in the middle on my square or created object and it works fine, the laser head moves to the correct position of the tile for alignment. The laser head finds the center just fine. But, when I choose the Frame option it completes the frame but it is about an inch off center to the top. So, another words it cuts about 1 inch off the bottom of the tile, and extends about 1 inch above the tile but is perfect on the sides. I have tried a couple of small projects but they mess up because of this.
