I just got the totem s 40w laser and was just learning light burn not sure if I change something by accident but now when I press the start button to start a cut or Engraving machine goes into home position and does not fire. Please help
Is the image to be burned selected?
Is the level setting lit as a result?
Yes it was selected it was actually an issue with my interval (mm) settings. Could you please give me a good range for a diode laser. CUrrently I use between .1 and .05
I did not understand the question…
0.1 to 0.08mm is the normal range for interval.
