Laser head move meant
first laser! got it 3 days ago. when I am burning a fill file. the laser head go’s 6" to 8" pass the cut. both direction
I did one. it would turned back after about 1" pass the cut, so I know it can work within the work area.
what did I do to make it raster shorter???
This is likely due to overscan setting and is deliberate to account for acceleration/deceleration at the ends of travel.
If you enable traversal moves in the Preview window you should be able to see the overscan moves.
Overscan can be adjusted in the cut settings.
