Laser head not moving and main panel on my LS3655 is not lit
Laser head not moving and main panel on my LS-3655 is not lit.
There is power in the machine as laser light is lit and temperature is showing.
Anyone has this situation? Thank you
Peter
Look at the Ruida controller and ensure the +5V led is illuminated and the err led is not. On mine, the +5V and err leds are 15 and 13 respectively.
Unless these run off the 24V of the controllers power supply, it doesn’t mean much except the machine has mains power to at least one power supply.
The motors and Ruida both run off the same voltage and usually the same power supply.
Thank you. Greathelp. My #15 light is blinking and #13 is of. What does ir mean?
Thanks again, Peter
Will be talking to tech support/service at BOSS laser Monday am first think, as I need that machine to work asap.
On mine - after boot and homing operations, nothing executing.
LED 15 (+5V) is on
LED 14 (run) is flashing
LED 13 (err) is off
LED 12 (link) is on (I’m connected on Ethernet)
Sounds like the +5V LED is missing, it should be on solid… not flashing
Do you have a voltmeter? Do you know how to check the 24V supply with it to see if it’s OK?
I would think Boss would have similar questions.
