Laser header won’t move
Currently having an issue with my laser head. There’s no movement at all, I press the home button or go to origin and still no movement. I’ve had this machine for about a month and haven’t been able to do any projects on it.
Hello Maribel neither have I same problems I have reached out to support no help.
Welcome to the site…
When you power it up, does it move to one corner or home properly?
If everything is dead, go check the power supply and ensure you’re getting power.
It’s always smart to shoot off an email to the vendor… It usually takes 24hours a cycle, before you normally hear from them.
Is the problem happening on the laser’s local controls as well, or only on the controls from LB?
I don’t have any experience with the controls in LB as I just run my jobs locally from gcode on a thumbdrive.
