I cannot get my laser to connect to lightburn. I have a Genmitsu 8. I have unplugged and plugged back in all of the chords and power supply. I have tried to readd the laser and that didn’t work. My computer is showing that I have something plugged in but when I try to get something to run on Lightburn, my laser doesn’t move.
The PC and laser have to be talking to each other. First, you create a Device in the Laser window. Use the Create Manually method because it is dirt simple.
If you have an issue with this, let us know.
If you already have successfully created a Device (GRBL), then:
- Enter $$ in the Console window.
- Copy everything from that window and paste it in a Reply.
Welcome to the forum. The only bad question is the one you did not ask.
