Laser is not working moved
I have a problem with laser is not moving at all. I bought a new laptop then click Device and Find My Laser it was appear “GRBL” it seem not work right then click Create Manually it found 3 list GRBL… don’t know sure which one? mine is Atomstack A5 Pro 40W Laser Engraver machine to connected right one and still struggled with it through what is going on since check YouTube video and Console report etc not understand at all and not expert! it’s complicated to me where and how? Let me know with helpful needs I would be appreciated. Thanks! See 3 pictures below
A few suggestions:
  1. Can you confirm if this machine has limit switches or not? I was under the impression that this did not ship with switches. In that case, disable Homing ($22) as well as disable “Auto-home on startup” in Edit->Device Settings
  2. If you disable homing you need to manually home your laser. Turn off machine, manually move the laser head to front-left of machine. Then start machine. That will be your home position. Do not move the laser by hand after starting up. Use jogging controls in Move window exclusively.
  3. Switch to “Absolute Coords” in Laser window Start From mode.
Got it! It’s working now! Thank you so much!!!
