I have an OmTech 80W laser with a 28x20 inch cutting bed. Lightburn is updated. Each pass on my cuts is slightly off now. What is causing this issue?
Can you show an example, it makes things easier to judge.
Mechanical issue, most likely a loose set screw or worn bearing.
