I set up a burn and burned the template layer, it worked great. I set the piece of wood in place then went to frame the burn I was doing and nothing happened. According to light burn it said it was busy. Any suggestions would be greatly apprciated.
It’s the usb connection… Sometimes it’s flaky… Take it out and re insert it… You should hear a tone from Windows computer…
Some seem more stable than others.
Might set the port to ‘auto’ if it’s there…
Good luck
