Been having issues with the laser for a few days now.
Laser SFA9
Material 3 mm
My old settings: speed 1000, Power 55, passes 4 or 5. I had no problems using these settings for a couple of years.
I have done the following:
Cleaned lens
Reset focus
Changed to previous Preference
Installed a new lens.
Now I can’t even cut 3mm material at the following:
Power 100%
speed 30
Passes 8
I know it has to be me. Any thoughts or ideas on what the issue is that’s causing this?
One last question. Do you get new preferences when you update to a new version?
Thanks for all or any suggestions.
…if it is mm/min, it corresponds to 16.6mm/s, you write that you are trying with 30 (???), - you write that you are trying with 30 (???), - if it is mm/s then it is almost 50% too fast…
Always remember the units of measurement
Good point. Thanks for chiming in. I needed a fresh perspective. Thanks again
The ratio between those is 33, which is close to 39, which suggests LightBurn was set for mm/min and is now set for inch/min:
This is the reason I have not downloades it. I have enough trouble with the older one.
I do not have the control units in my LB. Important ??
For sure!
- What version of Lightburn are you using?
- Screen capture (SHFT+WinKey+S) the Device Settings window and add it to a Reply.
