Laser just stopped firing after a couple months
worked fine on last use 3 days ago. go to use again and just moves around but doesn’t fire the laser
Most likely, the laser control cable / plug is broken. This is a very common issue if you didn’t fix the cable to the slider properly.
You can check by doing the 5V test and measuring the conductivity of the cable. Some explanations about the tests are here: Guide to mechanical adjustments and maintenance
