Laser line removal
Hi all,
New to using a laser rather than a router, I seem to get a good outcome of what it’s burning but I can’t get rid of the travel lines.
Any tips would be appreciated
Dai.
Hi David,
Generally when you see lines between your desired paths, it means your CNC machine is not in Laser mode, so it does not turn off the spindle (or in this case, a laser) between points. Presuming you’re working on your Foxalien machine as per your forum Profile?
Enabling and using laser mode on a FoxAlien machine requires toggling the physical hardware switch to “laser,” connecting the module correctly, and configuring Grbl settings ($32=1) in LightBurn.
We have some guidance here: Setting Up CNC-Based Lasers - LightBurn User Guide
Hi Colin,
Thanks for your response, on my machine I’ve toggled it to laser mode. I’m all new to the laser like literally my first couple of days into trying it. I’ll take a look at the configuration setting on LightBurn tomorrow and hopefully have a better outcome.
Thanks again
Good luck! Let us know if you hit any snags
Thanks Colin! I didn’t have laser mode turned on in lightburn, working great now.
