I am having a problem with framing the laser homes on power up can move laser by hand and hit home button and it returns home y-0 x-0.
Draw 2” squad and place it in the middle of grid hit the frame button and it will frame from y-0 x-0 out about 2” and up 2” not in the middle of the grid if I use the move button I can move the laser anywhere on the grid and hit framing button and it will frame from that position
Also the low power laser will not work when framing even holding the shift key down
You need to check, in the Laser window what ‘Start From’ and ‘Job Origin’ are set.
Probably should go over the Coordinate and Job Origin documentation.
