Laser Longer Ray5 40watt
Hello Lightburn,
I can’t connect my laser (Longer Ray5 with 40 watts). Lightburn’s search function isn’t working. It doesn’t recognize the laser. Even when I manually enter the laser model and dimensions, it still doesn’t recognize it. please help
Have you followed instructions? Installed dev file and driver?
LONGER Ray5 40W Laser Engraver Quick Start Guide - Setup, Software, and Operation
Thanks for the reply, I followed all the instructions. It’s like it’s cursed, I had a Longerray with 20 watts before and it worked without any problems.
Danke für die Antwort die Anweisungen habe ich alle befolgt . es ist wie verhext ich hatte vorher einen Longerray mit 20 watt und der lief ohne probleme .
Can you check if Windows detects the cable connection when you plug it into the USB connector?
