My laser Lost Connection about 80% into the burn. Do I have to start all over or can I pick a spot(somehow) that will save me some reburn time? And how do I do that? Thanks guys.
If you’ve not moved the material, you can use the preview feature. Advance the scrubber to the desired restart point, then use the “start here” button in the panel. Be advised, clicking the button will cause the laser to immediately begin the job at the new location.
Ok, I moved it close to the last position, where is the “start here” button?
Use the preview feature in order to use the correct start here button, as shown in the screen capture above.
Ha, I got it now. Start From: absolute cords? It still doesn’t want to start.
Did you fix the connection issue? Did you figure out why the laser disconnected?
You need to re-establish the communication with the laser, where is says ‘(Choose)’.
Yeah, I got it connected. I click “start here” it warms of possible out of bounds. I click start anyways. It will not start from that point. I’m not sure what’s going on now.
