Laser making 2 passes only set to 1 pass
I am cutting photo stands and the laser is making 2 passes but LB is only set to 1 pass, I have a ran the “find duplicate” but it said none found.
You might have duplicate lines in your workspace. If you Select All > Ungroup, then click and drag one of your parts around, is there more geometry under it?
You can also go to Edit > Delete Duplicates
If the second path is off something like 0.001mm, it is technically not a duplicate because it is in a different position.
I use what @Colin said a LOT. :grimacing:
That was the first thing I did and LB said it found no duplicates.
You have Grouped and Ungrouped shapes in the selection.
Duplicate the selection move aside and work with it to find the shapes. I usually Ungroup, Break Apart then check for Duplicates.
That might be right but it burns the hell out the plywood with scorched edges and I still don’t understand why it’s doing the second pass to start with. :thinking: :enraged_face:
Thank you. I will do that Friday as I will be away from home tomorrow.
The fiber has a global pass count in the framing window. I don’t know about other versions, mine is at 1.7
:grinning_cat:
Upload your offending Lightburn file (.lbrn2) so we can take a look at it.
Mike I will upload the file on Friday. Wife has a Doctors appointment in town Thursday.
Thank you. I did as us suggested and everything is to good to go!!
