Laser margin travel
Hello everyone, I have a Chinese 80w dr diode laser, when I center the material to be engraved, when I hit the shot the laser turns on but when I hit the path to see the margins the shot turns off, so I have to do it by eye , there is some way to not turn off the shot when performing the margin tour?
Thank you and excuse my English I’m translating with google
I believe you have enabled the Fire button in the Move window and set the power very low. That is the first step.
Hold the shift key and select the Frame button of choice in the Laser window.
Normally this produces laser illuminated framing.
I just confirmed this with my engraver locally.
After you follow @JohnJohn’s step to set power level in move window you can also permanently enable laser-on when framing in Device Settings.
