Laser marking stainless air assist
CO2 40w laser…using Ceremark…to get best results do I turn the air assist up to a higher pressure or down to a lower pressure…I’ve marked small coasters before and set at about 10psi, but I am going to attempt a large ss chopping block with a larger surface area graphic and I’d rather not mess it up :slight_smile: Thanks for any help you may be able to provide
