Laser master 3 le
heloo guys , i try to cut 3mm plywood, laser master 3 LE machine but i need 8 pass , 95 % , 15 speed for that, can you help me .S max in lightburn is 1000
Post image of your layers setting
Image of your module lense
You have the wrong controller selected
Is GRBL not GRBL-LPC
I would sugest deleting profile and creating manuyally a new one
Thank you very much, i think you are in right. I will try that.
Greeting
is that ok now ?
I would update to latest lightburn
Then change these 2. Turn off Z
and enable Laser on frame
Also make sure your device is selected correctly on the drop down at the laser pannel
i was finish that . i was cut 8 pass 100 speed 95 power . again :frowning:
