Laser master 3 ortur
Laser postion is moving to the right during photo engraving . Laser master 3 ortur
Are you on a honeycomb or a flat solid surface? I find this happens quite often when my air assist goes over the side and causes the work piece to shift because it is actually causing it to hover slightly if there is no relief underneath for the air to have an escape. if so, possibly put the piece on stand offs and see if it rectifies the problem
