Laser missing areas
Evening All,
I’m having issues with laser missing some areas, they are not random since it happen in batches.
You can see I have batch A and all of them have the same issue.
Batch B I was afraid of having the same issue so I only engraved 1 plaque.
Machine is a Neje Master 2S Plus, the machine is new, so am I to this hobby. Hope you guys can help me.
Engraving info: power - 20W, speed - 2000 mm/min
Material: MDF
Can you capture an image of the ‘Cuts/Layers’ window for your project?
If this is a ‘Lost Motion’ problem you may benefit from reducing speed and power both by 25%.
Are you using Flood Fill for this? Those gaps look like what happens when the Y axis returns to complete a shape, but has a bit of slop in the movement.
C24 and C01 are just for guiding.
Yes Oz, I’m using flood fill. Is that incorrect to do?
It’s not “incorrect”, it just requires a very well tuned machine for it not to leave gaps, unfortunately.
I used to save time but I’m trying without it. I’ll report tomorrow. Thanks for the support.
@LightBurn Disabling flood fill worked :+1:
