Laser moving backward
I don’t know what I did, but now my laser is creating everything backward, is set to start on left corner it moves to the right conner. The worlds are backward, and I didn’t do that at the beginning. Any way to reset or change the laser to the original setting. Thanks
Longer 5W
It sounds like you need to change your Origin in your Device Settings. You can do this by going to ‘Edit > Device Settings’ in the top menu of LightBurn, or clicking the wrench icon in your top menu bar.
The ‘Origin’ setting controls the orientation of what gets sent to your laser. For example, if you have the origin for the device set incorrectly, your output will be mirrored or upside down when run.
We have full guidance on how to change your origin here: Wrong Orientation - LightBurn Documentation
Please adjust your origin as per the guide above, and let us know if you have any issues. We’re happy to assist further.
That works thanks for the solution, now I got a problem when I hit frame the laser bump on the site and the front of the guards. Any way I can reset that. Thanks again
IF the machine does not have limit switches you will probably have to disable the “Auto Home at Startup” setting
Thanks that helps.
Thanks for your feedback! :ok_hand:
