Laser moving over whitespace instead of reversing to the next line
Hello, I’ve been using Lightburn for a few months now and just encountered an issue I’ve never seen. When engraving an image, the laser continues to move all the way to the right hand side of the image instead of reversion direction to continue printing. This is adding a lot of time, not to mention the wear and tear. It’s never been an issue before, and the image was processed in Imag-R. Here’s the image showing the transversal moves. Thanks for your help :slight_smile:
well that looks weird - screenshot your cut settings?
Do you see the laser flash at the ends of each pass (right side) of the image? I had a similar problem where I had inadvertently left a vertical line after image processing and doing the invert.
