I just downloaded lightburn feb 2022. Using sculpfun S9 laser. I am trying to frame the work, the laser does not show. I already installed the fire button at 25%, restart lightburn. using the shift key as suggested and still the laser does not show. It did work when I use it with LaserGRBL sofware. any suggestions please?
Do you see a light when using just the fire button? Also, 25% is extremely high for a fire operation. This would typically be under 1% and certainly not more than 5% depending on the situation.
How exactly are you using the shift key for the frame? Are you holding down the shift-key while you push the frame button? If not, try that.
Do burns work normally outside the framing issue?
Agree… I ran two different atomstacks.
Hold shift and click the circle frame.
This was such a helpful tool.
I usually ran 1 maybe 2%.
If i wanted to mark the material then i would crank up to 15-20 and momentarily press the laser button.
If you are c02 laser… This function doea not apply.
25%? Is not possibile in LB to go over 20% for activate button
Thanks. I appreciate it a lot. It was set at .025% my bad. also holding the shift key. it worked.
