Laser not burning anything
I was trying to make raised text in a square. Since then every file i create the laser goes thru the motions as cif it is burning but doesn’t burn anything no matter what my settings are.
Do you see the blue light from the laser?
  1. What is your speed setting, in mm/minute.
  2. What is your power setting in %?
  3. How do you focus your laser?
  4. What material are you trying to engrave?
  5. Has it worked before or is this your first try?
  6. Does the laser move properly when using the Jog controls in the Move window?
All of these questions are important. Please try to not leave any out when answering.
Fixed my issues. Thanks again.
I see you did not say what was done to fix your issues, here or in the other Thread. We covered a lot of ideas. Would you mind saying what it was that got you going? :nerd_face: Someone with the same issue might benefit from it.
I was playing around trying to fix it. I did several things and it started working. I don’t know what I did to fix it.
Been there and done that. Glad it is working for you.
