Here is my code. S value matches and I have laser power in my cut settings at 100%. Still is not cutting I can see the laser light but is not cutting. Could my actual laser be broken?
Are you able to compare the current draw to what it’s supposed to be? I have a small engraver(1000mw) arrive with a bad diode. It would show the dot but not actually do anything else.
If you are requesting that your machine move faster than 1000 mm/minute (about 16.6 mm/sec) it won’t, because these settings prevent it, so it will reduce the power level instead.
With your machine requiring 800 steps to move 1mm, you’re going to max out at about 2000mm/minute tops.
