Hi all, TwoTrees TTS-10 , Latest Lightburn update, Windows 11,300mm x 300mm base. When cutting a rectangle 280mm X 6mm. One end ends slightly smaller than the other, One end is 6mm and the other end is 5mm. What can cause this. Any help would be greatly appreciated.
Hi Paul
If you move the gantry all the way to the back or the front and hold one side with finger presure, is there any play at the other end. Are the X and Y axis square (90 deg) to each other.
are the belts properly tensioned on both sides. Have you just assembled the machine or is this a new issue that just popped up.
Is your design and material properly square. Does the cut taper gradually out to 6mm from 5mm.
Thanks for that Peter , The x and y axis was out by 3.5mm. Cuts great now.
