Good after noon, I am working with my guy here to troubleshoot our Omtech 100w co2 laser with Lightburn(lastest as of now). After getting the MB replaced and finally getting the mismatch on cut dimensions worked out, it seems that we have another issue. I am thinking the software has a place to adjust, but I’ll be damned if I can find it. We are using the Omtech test file and the settings are off. I am either looking to adjust down the speed or up the power(not engraving as deep). I would assume the test file from Omtech has the correct settings changing from one layer to the next, but the global settings on the whole machine, or the entire file need to be changed. How can you affect a change on all of the layers at once? I was thinking like changing speed down by 20% or so. Power could go up too, but again looking to make a change to the whole shebang instead of one layer at a time. THanks ,Chad
