Laser not engraving or cutting
My laser is not engraving or cutting anything and I have checked the focus and all settings seem fine. It frames the project and if I click start, the gantry and diode move and the laser light does get brighter as if cutting but it does not eaten make a mark on the wood.
Has anyone else run into this problem before and can you maybe give me a possible fix for the problem?
Hello George,
WHat Neje frame and module?
Can you share a screenshot of your project showing the Cut&Layers panel?
are you in mm/s instead of mm/m for your settings ?
