Laser Not Finding Absolute Coords
What i see on the screen does not match what my machine is trying to do. When I choose the marker position it goes and hits the limit switches of the front of the machine. The display coordinates appear to match the lasers position. However whenever I place an item in the middle of the design area and set start from to absolute coordinates it does not move to the correct spot. It ends up hitting limit switches instead.
Does you Ruida boot and home properly? It should not hit anything if itā€™s properly configured. It ā€˜knowsā€™ the machines boundaries.
How did you configure the ā€˜Device Settingsā€™ and the ā€˜Machine Settingsā€™?
Where does your machine ā€˜homeā€™ on power up?
Is that the same corner you have it configured?
Jack,
I think he may be using ā€œhitsā€ figuratively vs literally.
From reading the OP Iā€™m not sure if he has a diode or CO2 laser.
To be able to help we are going to need more specific information including the type of laser and what coordinates he is telling it to go to and exactly what the laser head is doing.
The profile says ā€˜DSP Ruidaā€™ for the controller, so for this, type of laser isnā€™t really a concern.
If itā€™s a properly configured DSP it should not even attempt to move the head as it ā€˜knowsā€™ the machine limits will be exceeded. Thatā€™s where you get the ā€˜slopā€™ error.
Something else is going on or I misunderstood his description.
Is this a diode laser? What version of Lightburn? When did you last upgrade?
Has this ever worked or is this a new behavior? Or have other things worked and this is something different youā€™re trying to do?
Just to see if I follow your postā€¦
You turn on your laser and it homes correctly to the front left corner where the limit switches are. The location in Lightburnā€™s Move tab says X:0 and Y:0.
Correct so far?
Then what do you do? Screenshots will be helpful.
One other thing to try is while the head is homed, go to the move tab and type 300 in X and 400 in Y the click Go.
What happens and please be specific as possible.
In fact, this is a normal phenomenon, because when starting the cut, X,Y, axis need to go back to the origin, before entering your design area.
You do realize this is the Lightburn forum, not RDWorks.
The Docking Point feature, if enabled in the controller, will return the controller to the docking point after each job, regardless of software. :slight_smile:
So honestly I just got the laser and I am completely in the dark on knowing how to get everything configured like I need too. Iā€™m used to the Diode lasers and so this is something totally new to me. Something is way wrong though because when I use the waypoint to move the laser around it just takes off to the front left corner no matter where I click the waypoint in light burn.
You have a configuration issue from what I can see.
Is this a new machine?
Did you go through the Lightburn Ruida configuration and the Coordinate and Job Origin documentation?
I am having issues with the laser grinding against the left X Axis and making an awful grinding noise and itā€™s like itā€™s not reading the correct size of the bed. I can reset the XY Axis but every time I turn the laser off and back on again it starts this all over again. Iā€™m not seeing anything on the internet of how to fix the issue. When I reset the XY Axis everything works like itā€™s supposed to. Yes this is a new machine. Thanks again
Have you contacted the seller? If you think itā€™s not reading the correct size of the bed, have you tried creating a new profile in lightburn with the correct sizes on the correct axis? Your Ruida controller might not have been setup properly and you might need to adjust x and y axis size there as well as home location. Your limit switches should stop this from happening by default.
Youā€™ve pretty much lost me. Iā€™m not sure I know what the problem really isā€¦ Trying to followā€¦ The basic idea is the same for any cnc machine, same concept as the your LED laser
If itā€™s new, did it ever work?
If so, what did you change?
Apparently, it doesnā€™t home?
It doesnā€™t ā€˜readā€™ the bed size. It knows itā€™s bed size from itā€™s internal configuration and ā€˜homesā€™ to know itā€™s 0, 0 position. If it canā€™t ā€˜homeā€™ it doesnā€™t know where it is.
If it canā€™t home, thatā€™s where you start your trouble shooting, since thatā€™s itā€™s first move and itā€™s failing.
This problem is most likely with the controllers configuration, not software.
Relax and answer these questions posed to you. It will simplify your ā€˜ordealā€™ :slight_smile:
We call them limit switches, but they are home switches on the Ruida. Their only use is to tell the machine where 0, 0 is. If they trip while the machine is in normal operation, the Ruida will ignore them. Iā€™ve reached in there and tripped themā€¦ nothing.
On my grbl machine, they do halt it during operation.
Even the Lmt*+/- inputs, donā€™t appear operational unless the controller homes properly. It seems pretty handicapped if it canā€™t home.
