When I load a sample file that was preloaded on machine everything works as expected. When I send a file with lightburn it does everything right except fire the laser.
I have check the machine setting and the laser is activated. Any help would be appreciated.
What are your settings? If you do not set min power high enough, the tube might not fire. (“High enough” is about 10% of the wattage of the laser, as a ballpark)
I usually check if the chiller (or the pump) is working and the water circuit is circulating, there are no leaks and no medium or large bubbles (there may be some occasionally but very very small) and of course the ventilation system is working, although the chiller is usually what prevents the laser from starting if it is not working.
This is a learner’s response, since I have only been using the laser for a short time, in case it helps you.
I have it set for 20% on low. I have found that if I create the design fully in lightburn that everything is fine. The svg that I imported just goes throught the motions but does not fire the laser.
Please attach a LightBurn project file that does not fire for you so I can take a look at the file contents, or email it to us: support@lightburnsoftware.com. I suspect that you have a setting incorrect.
