berainlb
(PY)
August 24, 2022, 12:50am
21
Okay. That looks right. I’m fairly confident that your controller is sending the right signals.
Does the laser light come on and stay on when you check?
I’m fairly certain that if you’re not getting a laser led indicator that the PLH3D controller is not detecting a signal.
However, try measuring HEAD SUPPLY to G and HEAD ANGIN to G:
There is also a troubleshooting guide on P. 27 that you may want to step through.
berainlb
(PY)
August 24, 2022, 1:08am
22
Saw this on a page about PLH3D-6W-XF laser. Not sure if this is what you have. This gives more detail about the the connector that plugs into the adapter.
Also a view of the port with pin numbers:
Based on this you may want to test pin 2 to 3 as well.
So overall test:
Analog signal - 1 to 3
TTL signal - 2 to 3
Supply voltage - 5 to 4
bedellgs
(Gary Bedell Jr)
August 30, 2022, 1:56am
23
Sorry…I’ve been out of town. I will test soon and post results here.
system
(system)
Closed
September 29, 2022, 1:57am
24
