Laser Offset issues
First off, I LOVE Lightburn. You have done an amazing job with it.
I know this has been discussed and dismissed previously.
The laser offset setting seems to be total mess.
It works fine if you only use relative coordinates, but if you do anything with absolute coordinates it screws everything up unless you turn the offset OFF.
It seems inconsistent. On absolute burns I checked the framing with the main laser, not the pointer as it is way off from the absolute coords. But then when you start it, it applies the offset. Maybe I’m missing something, but having to go into the device settings when I switch from an absolute setup to a relative setup is a mess.
I do not think there would be a need for Laser Pointer Offset in Absolute Coords mode. I do not even see this mode mentioned in the documentation.
