I am having this problem where the laser does not respond to the shadow parts of the image. See attachef
Hoe can this fix? I have version 1.5.06
If i had to guess you have a mechanical issue with your wiring
Seems a motion driven bad contact on your laser wire
Suggest you go over each connector, and all the wiring and inspect it well
Also set laser to say 2-3% and touch the connectors and wires and see if you can make it stop firing
Lastly $i in console to see your firmware version
You hit it on the head! Thanks f
I rewired the head securely and made sure that it does not get pulled. I got this beautiful image!!
Great news!
Amazing engrave too by the way!
