why is my laser only firing at slow speeds? I have tried several different max/min powers and speeds and my laser only fires when i have speeds lower than 5mm/s. I have a 3018 with a small blue laser…either 5W or 0.5W not sure.
just trying to cut some yellow manila folder cardstock
5mm per second is 300mm/min
If you exceed the Maximum rate (speed) the controller will reduce power accordingly.
You can see and review the settings in the Console window in LightBurn.
To get a full report of the settings Open the Console window and type the following:
then press enter.
Copy and paste that report into a reply here if you’re interested in knowing more about those settings.
