I have a ruida 50w laser while I can cut files no problem at all with lightburn it seems to not like photos. I used imagR to prepare and set to passthrough. When I send to the laser lightburn beeps but still sends the file, yet the laser doesn’t start lasering.
What settings are you using for the file? (DPI, speed, etc) Do you have a lot of files already hosted on the laser? Do you know how large the file being sent is, and do you have room for it on the controller?
Thanks, I believe it’s the space on the controller that’s the issue, I’m just trying to work out how to clear it off.
Thank you for your help.
In LightBurn, go to Window > File List (just to show it)
In the file list window, click ‘Refresh’ to see the list of files. If you want to delete all of them, click ‘Delete all’ in the bottom right, otherwise, delete one at a time from the end of the list backwards (it’s faster that way).
